AutomationDirect Customer Forum
Welcome to the AutomationDirect Customer Forums.
These forums are intended as a place for AutomationDirect customers to help one another, share information, and share ideas.
The forums are not routinely monitored by AutomationDirect Technical Support staff. While staff members may answer questions occasionally, for a prompt response to a problem please contact Technical Support directly at: 1(800) 633-0405 or (770) 844-4200 or e-mail Tech Support.
Go Back   AutomationDirect Customer Forum > Operator Interface
Reply
Thread Tools Rate Thread Display Modes
  #1
Old 11-05-2009, 04:38 PM
MAGOO5150 MAGOO5150 is offline
Registered User
C-More to AB 5/04
I am working on a project where I am monitoring tank levels with ultrasonic sensors w/ 4-20 out. This was done with a 5/04 and a panelview. I replaced the panelview with a C-more 8" and seems to be working okay except I get an error that says PLC-499 ERROR 0X1000. I can not find any info on this. Any suggestions? Any help would be greatly appreciated.
  #2
Old 11-06-2009, 08:34 AM
HMI Eng HMI Eng is offline
Registered User
It means you are calling an address with the C-more that has not been defined in the PLC. Go to the C-more error screen and it will show what address is causing the problem.
Reply
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
