Go Back   AutomationDirect Customer Forum > Examples and Programs
Bookmark and Share Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 04-26-2011, 10:29 AM
celect celect is offline
Click PLC Calender/Clock
Has anyone ever used the real time calender/clock to control outputs?
Old 04-26-2011, 11:08 AM
Bob S BN Bob S BN is offline
No, I haven't used the Click Line at all but, until somebody else chimes in, according to the Programming help software>contents>reference>system data registers, the RTC values are stored in SD20-SD26.
You would use these values in the "Compare" contacts and compare them to limits of your choosing, and cause an output accordingly.
Hope this helps,
Bob
Old 05-01-2011, 12:38 PM
Sample
Here is a sample I trying to program.
Old 05-01-2011, 02:37 PM
milldrone milldrone is offline
celect,
Try this
PERCUSSIVE MAINTENANCE: The fine art of whacking the devil out of an electronic device to get it to work again.
Vaughn
  #5
Old 05-01-2011, 10:03 PM
I don't understand how c1000 will be reset.
  #6
Old 05-01-2011, 11:13 PM
Quote:
My apologies. I did not have a CLICK to test it on, but this should work.
Vaughn
  #7
Old 05-02-2011, 09:47 AM
Thanks for your advice and corrections to my program.
If I'm using a Click PLC with battery backup, does that keep the RTC going during a power failure?
  #8
Old 05-02-2011, 09:56 AM
Do-more PE Do-more PE is online now
Yes , the Battery powers the RTC when it is not otherwise powered.
If you have an urgent issue, please contact AutomationDirect's Technical Support team.
AutomationDirect.com Technical Support: 1(800) 633-0405 or (770) 844-4200 Email Tech Support
  #9
Old 05-03-2011, 11:27 AM
Thanks for the info.
  #10
Old 06-27-2011, 09:59 PM
jthain21 jthain21 is offline
does anyone know how to create a line of code that would enable me to chose from a touch screen (like a c-more micro) what day I wanted something to happen. Example, Maybe I want to shows a tuesday at 7pm, or maybe I want it to happen on sunday at 6am. Thanks for the help.
