Go Back   AutomationDirect Customer Forum > New Product Announcements
Bookmark and Share Thread Tools Display Modes
Old 09-06-2012, 12:05 PM
Do-more PE Do-more PE is offline
September 2012 - H2-DM1 & H2-DM1E Do-More PLC CPU's
We are pleased to announce the addition of the H2-DM1 and H2-DM1E Do-More PLC CPU's! The Do-More Designer software features an all new instruction set to leverage all of the power these new CPU's hold!
Each Do-More CPU comes with free 30 days of training by Interconnecting Automation AutomationDirect's official training partner! Combined with our new H2-DM1-START and H2-DM1E-START starter kits you can get up to speed in a hurry!
The Do-more H2-DM1 series PLC CPU module features 192k words total (64k words ladder (flash memory), 128k words user data memory (SRAM with battery backup)).
Ladder programming, real time clock/calendar, two built-in communications ports: (1) RS-232 port supports programming, K-sequence slave, MODBUS RTU master/slave and ASCII IN/OUT; (1) USB port supports programming.
Supports bumpless run-time editing and 2000 PID loops. Battery included.
Requires Do-more Designer programming software (free download online). User manual H2-DM-M available as a free download, or purchase hard copy separately.
The Do-more H2-DM1E series PLC CPU module features 192k words total (64k words ladder (flash memory), 128k words user data memory (SRAM with battery backup)).
Ladder programming, real time clock/calendar, three built-in communications ports: (1) RS-232 port supports programming, K-sequence slave, MODBUS RTU master/slave and ASCII IN/OUT; (1) USB port supports programming; (1) Ethernet port supports programming, TCP/IP, UDP/IP and Modbus/TCP.
Visit the Do-More product specific website, the Do-More Video Library or the AutomationDirect webstore to find out more!
Please note that Do-More designer is not compatible with DirectLogic CPU's, nor can existing DirectLogic programs be imported into Do-More designer. We had to do a clean break with the old way of doing things in order to give you the best possible new PLC experience that we could.
If you have an urgent issue, please contact AutomationDirect's Technical Support team.
AutomationDirect.com Technical Support: 1(800) 633-0405 or (770) 844-4200 Email Tech Support
Display Modes
