productivity 1000 plc to step driver with SCL
    The Post Count MUST Grow!
  • Kp386
    That's the exact information I needed. Thank you!
    Originally posted by Kp386 View Post
    I am also trying to find a pinout for the cable I should be using between these ports. The cable I'm currently using is 1-yellow 2-red 3-blue 4-green 5-white 6-G. To 1-G 2-white 3-green 4-blue 5-red 6-yellow. To make it less confusing its 1-6 2-5 3-4 4-3 5-2 6-1. does anybody know where I could find out if this is the correct cable? or is anybody able to verify offhand if it is correct?
    have you looked at this
    check out these threads:
    https://forum.automationdirect.com/f...ivity-1000-plc
    https://forum.automationdirect.com/f...g-to-ascii-out
    https://forum.automationdirect.com/f...-using-p1k-plc
    https://forum.automationdirect.com/f...eek-home-issue
    edit: ah Kewakl beat me to it. I should have refreshed the page before replying.
    look here and here.
    OP had issues with P1 and SCL stepper. Maybe you can get a bit further after reading these threads.
    Let us know.
  • Kp386
  • Kp386
    started a topic productivity 1000 plc to step driver with SCL
    Hi,
    I'm trying to send ascii commands to step motor driver Via SCL. Using my computer I am able to send commands to the driver with "sure motion pro" via the SCL terminal window. So I know the driver is set up correctly and waiting for commands.
    I have not been able to find an instructional video that deals with sending ASCII to a driver on the productivity plc. I know there is an instruction that says specifically "Send ASCII" in the productivity software. I am trying to use this to send my instruction. Is this the correct thing to use?
    I did set up my RS-232 port for the correct baud rate stop bits and parity. But I am not convinced this is working. Are there any kind of tests or diagnostics I can run to make sure they are able to communicate correctly? example, a SCL terminal window in productivity would be Brilliant!
    Thanks for any help,
    Kyle Price
