Click PLC Calender/Clock
  • jthain21
    does anyone know how to create a line of code that would enable me to chose from a touch screen (like a c-more micro) what day I wanted something to happen. Example, Maybe I want to shows a tuesday at 7pm, or maybe I want it to happen on sunday at 6am. Thanks for the help.
  • celect
    Thanks for the info.
    Yes , the Battery powers the RTC when it is not otherwise powered.
  • celect
    Thanks for your advice and corrections to my program.
    If I'm using a Click PLC with battery backup, does that keep the RTC going during a power failure?
  • milldrone
    Originally posted by celect View Post
    I don't understand how c1000 will be reset.
    My apologies. I did not have a CLICK to test it on, but this should work.
  • celect
  • milldrone
    celect,
    Try this
  • celect
    Sample
    Here is a sample I trying to program.
  • Bob S BN
    No, I haven't used the Click Line at all but, until somebody else chimes in, according to the Programming help software>contents>reference>system data registers, the RTC values are stored in SD20-SD26.
    You would use these values in the "Compare" contacts and compare them to limits of your choosing, and cause an output accordingly.
    Hope this helps,
  • celect
    started a topic Click PLC Calender/Clock
    Has anyone ever used the real time calender/clock to control outputs?
