Did we loose Pointer?
  • Did we loose Pointer?
    Hello,
    Trying to set a table to store parts count every hour in an increment series of memory locations without needing to write a new line for each hour of the day, I believe in DirectSoft you could do this with a pointer using INCB instruction ( I never set up But played around with it and got working) But I am at a loss with DoMore Any suggestions?
    No, we improved on it.
    All memory blocks are indirectly addressable via array indexing...Block[Index], where Index is the address of Block. If V13 were equal to 100, D[V13] would return the value of D100. Incrementing V13 (to 101) would then return D101.
    This works for all blocks, even structures, like T[V5].Acc.
    In normal ladder code, only V can be an array index. Within MATH boxes, array indices can be full expressions like C[D5 + sqrt(N2/PI())]. In the MATH box the output value can also be a full array expression. Very handy for doing multi-dimensional arrays, D[XIdx + YIdx*RowSize] = Expression.
      Yes, this is waaaaay better than the DL pointer.
        I guess I need to play with this one to figure it out, thank you !
          Could you elaborate?
            Sure.
            Let's take a 2 dimension array. Let's say each row consists of 10 columns, and there are 10 rows. Allocate a single block of 100 items and call it ARRAY.
            In languages that support multiple dimensions, you would access row 3/column 5 like this: ARRAY[3][5], but all you are really doing is accessing linear memory with some simple math...ARRAY[Row*RowSize + Col]...or ARRAY[3*10 + 5].
            Since Do-more allows complex expressions for both the right and left side of a MATH box, it is easy to build and access n dimension arrays. I'm showing 2 dimensions, but this can easily be extended to 3 or more dimensions.
            So let's say you wanted to fill our example ARRAY with values:
            FOR Row = 0 to 9
            FOR Col = 0 to 9
            MATH ARRAY[Row*10+Col] = My source data
            NEXT
            NEXT
            Here it is in code. I created Symbolic Constants for the dimension values so the code is more readable. It also makes it easy to change the size later. Row and Col are just D locations.
              Good stuff Bob!!
              Thanks.
                I was able to get all figured out, much simpler than I was making it! able to log hourly number into a new location every hour then on request (Will change to specified time) store to CSVfile and at the end of the day go back to the original location
