Instruction Help
  • Todd Dice
    @Todd Dice what is this Return you speak of?
    Well, it's been awhile since I programmed in RSLogix, but doing so many Clicks nowadays I "misremembered" that A-B has no return. "I should'a had a V-8!"
    Originally posted by Todd Dice View Post
    For me, I've placed all my tasks (subroutines) in the "Run Every Scan" folder. With this method, no JSR is needed, and neither is a Return.
    I do a bit of all three:
    1. Call the Called tasks - when needed
    Heavy, intermittent load - like a lot of math on array data
    Intermittent processes - charging and discharging multiple capacitors
    2. Call the Called tasks - Called all the time
    3. Run Every Scan tasks
    @dknieder You determine how you need to run your processes. You have flexibility. We can give some guidance.
  • Todd Dice
    Originally posted by dknieder View Post
    Is there a JSR instruction and how do you do subroutines in Productivity Suite. I am using a p1-550. Thanks
    Unlike Allen-Bradley, in Productivity, tasks (aka subroutines) can be created in one of 4 sub-folders inside the Task Management pane in the left-hand side of the editing screen. I believe when you read the titles of each folder, you'll understand what each does and can answer what you're asking. For me, I've placed all my tasks (subroutines) in the "Run Every Scan" folder. With this method, no JSR is needed, and neither is a Return.
    You can create a 'Run When Called' task and Call it when needed.
    You can call tasks from other tasks - just NOT from 'called' tasks.
  • dknieder
    started a topic Instruction Help
    Instruction Help
