PAC suite
    Originally posted by PSeries_Eng View Post
    We asked about magnification. We also tested with magnification (even though you said it was at 100%) and do not see the issue with 3.2.2.4. We will test further.
    --I hope that by 'magnification' you didn't mean 'custom' text size (dpi) -- as Mike suggested in post 12. My eyes do require larger text. I do have that NOT DEFAULT. 125 or 150 depending on site.
    -- I thought that you asking about any magnifier program/application/theme.
  • PSeries_Eng
    What is your screen resolution and your screen magnification set to?
    Default for monitor and 100%- Purely default and default.
    What are your settings?? If we can get these maybe we can work to get fixed.
    I mentioned in post 9 that the work laptop is 1920 x 1280, I just checked at home. Same.
    I think that Mike hit it when he said 'custom text size.' I had it set to 150. It would be great for the pac and solo to be able to handle NON-STANDARD vanilla stuff.
  • PSeries_Eng
    Originally posted by MikeN View Post
    I just watched your video and tried that myself, couldnt duplicate it :/
    I am on a Windows 7 pro SP1 PC using the latest productivity software that is currently available. I thought maybe it was your theme you were using so I switched mine to WIndows classic as well but I still copuldnt replicate this issue. Is there some other theme altering software on your computer? And you are sure that your "set custom text size (DPI)" is at 100%, and the general "make text or other items larger or smaller" screen is also set at 100%?
    Mike, If I were giving awards to the MOST CORRECT answer, you would get it.
    If I setup WINDOWS for automationdirect software, I can get rid of this issue, but I NEED the larger font.
    Except Solo, I do NOT have this issue with other automation software.
    Do you need to update your video card driver?
    I tried to duplicate your problem, and I could not make the window any smaller than the buttons remaining at the bottom.
    Can do when I get a break in this action! Thanks.
  • PSeries_Eng
    Can you:
    1) Start a new instance of the GUI with no other instances open. ( Preferably 3.2.2.4)
    2) Make this happen.
    3) Send the log file from the following location on your pc C:\ProgramData\AutomationDirect\Productivity Suite 3.2.2.4 ( or whatever version you reproduce it on.)
    and on laptop
    both win7 pro sp1
    homepc has MSI RX 480 8GB.
    This laptop is a crummy HP zbook with intel HD and invidia quadro M1000M video 1920X1080
    This clip is from V1.7.1.1
    Originally posted by Ridgeline Mach View Post
    I do not have this issue, and I am using a 17" Toshiba Satellite L55-B5294 Windows 7 Pro laptop.
    kewakl, can you post a screenshot?
    thanks. Did just a bit better than screenshot.
    kewakl
    We were TRYING to get more info.
    Understood. Thanks.
    short vid clip from home using camtasia camstudio recorder
    looks the same at the shop. I'll try all the revs that I have installed.
    [edit: fix camsoftware name]
  • PSeries_Eng
    kewakl
    we had a QA guy trying to duplicate and could not make the window small enough to hide the buttons. I also tried with no success. We were TRYING to get more info.
