CMore EA9 communication with Schnieder Modicon M241.
  • CMore EA9 communication with Schnieder Modicon M241.
    How do you communicate to a C More EA9 from a Schneider Modicon M241 thru ethernet? i can't find any info on this. Communication and tag set-up for each?
    Think it's easiest to set up on the C-More side. Seems likely that setting the communication to "Modbus TCP/IP Ethernet" is a good place to start. You'll need to know what IP your M241 is set to. Addresses for discrete inputs and outputs are typically 0 and 1. For analog I/O it's typically 3 and 4. EA9 should be able to read off PLC.
